Help!! Power steering
bakoburban
Bakersfield, CA
Alex
Suburban 2500 4x4
5.7L
Hello Guys,
I have an '85 K2500 4x4 and I just replaced my leaking power steering pump with a rebuilt cardone. I also changed the high pressure hose After doing the proper bleeding routine I started it up and have no power steering at low rpm but have it at high rpm.
I've contacted cardone and they are telling me it is a stuck or bad pressure regulating valve, so I swapped it and nothing changed. Then they told me to gently tap the back of it with a rubber mallet, but that did nothing either.
Do I have a bad pump? Should I just swap it out with another rebuild? It is almost impossible to turn the wheel at low rpm, almost like somthing is in a bind. The steering worked perfectly before I changed the pump, just leaked.
THANKS
Moderator
You need to try another pump, it's not uncommon to get a bad one.
Man that sucks.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I've had several bad pumps new. I started ordering the oldsmobile diesel car pumps and changing them over in my housing. Seemed to make more pressure and easier steering
bakoburban
Bakersfield, CA
Alex
Suburban 2500 4x4
5.7L
So I guess I'm just screwed. It's not the effort it takes to change it out, but the time is tough to find.
Thanks guys.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Cardone is autozone right? Thats what I have in my truck.
If I try and coast and turn at the same time I dont have power steering, its just pure junk ass ****. The original I replaced would turn the wheels at idle with no effort.
bakoburban
Bakersfield, CA
Alex
Suburban 2500 4x4
5.7L
Cardone is from Carquest. I bought another one, installed it and it works now.
tjd50317
des moines
tom
k2500
i think i got 2 bad pumps from oriellys ended up getting a agr from summit a lot more money but i think it solved my problem. Tom
Jesus that's amazing how many bad ones are being sold. Definitely got to keep this in mind and shop for better quality for this part.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
WOA guys ALL parts houses sell Cardone. They are just a rebuilding company. ALl of the core items i take off of engines i tear down at work go to Cardone to be rebuilt and sent out to all of the major parts houses across the USA.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
So does anyone know if you can use a pump from a 3500 on a 2500 i keep blowing up my pumps I'm on number 6 in 5 years all warranted by o'Rielys. but I"m looking into running larger tires. whats my best option? also I've replaced the entire system so far pump, hoses, and steering box. I'm running a 5.7 tbi on a 1989 v2500 4x4 suburban.
Probably better off getting a used factory on from pull a part or go try a different parts store?
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Psc pump and res is on the list for me i go through a pump every year apita
Anybody try going with an ACDelco unit?
