Help ID what year gauge cluster
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I have a 82 C10 and not all the gauges work. A few months ago my neighbor gave me a gauge cluster that's in really good shape. The problem is mine uses a Speedo with a cable and the one he gave me looks to be electrical. Can I still swap them or will it not work.:shrug:
I looked all over for part numbers or some kinda identifying number but no luck. Sure wish I could put it in mine but, I'm thinking no go. Hope I'm wrong.
nvrenuf
Mobile, Al.
90-91 R or V series squarebody w/ VSS, relatively valuable (~$200). Most of the wiring is different on these from previous years so it requires a fair amount of tracing / repinning of the harness plug to retro fit.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Alright, thanks.
Other than the speedo and back housing, isn't the rest of the gauges and the face the same?
82sbshortbed
Fuckemall!!
SE Texas
Doug
I thought so too.
nvrenuf
Mobile, Al.
Yes, the gauges are interchangeable with other years (assuming you have the correct sender) but the printed circuit on the rear is different both in shape and circuit routing.
jon wandvik
