Help. Car won't turn over to start.
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Truck started great before I installed Intellitronix gauges.
I installed gauges with temporary connections. Gauges work, Started OK.
I removed all temporary connections and made them permanent.
Now I turn key; gauges light up.
Makes one "ugg" then nothing and gauges turn off.
New battery. I needed it anyway. Charged to 100 percent. Voltage over 12.5.
Removed starter. Starter and solenoid look brand new. Attached to new battery with with jumper cables. Jumped S terminal to positive jumper cable connection.
Solenoid snaps gear forward. Starter spins like a mo' fo'.
I did the easy stuff first, new battery, tested starter motor.
I guessing something in the electrical system is either drawing too much juice, or it gets grounded some way.
Before I take the gauge panel out to check all connections, looking for suggestions.
It's gotta be the gauges, no?
While typing i was thinking. I'm gonna disconnect all power to the gauges. Install starter and try it.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
If it worked before the permanent install. Back track, even unhook wire by wire till it starts. That is what I would do.
73c20jim
Sierra Vista, AZ
I was hoping you would not say that. First i'll try disconnecting the 12V always, Ignition wire and ground wire.
Comments.
4WDKC
Southern Florida
Kacy
take starter to parts store for load testing, it spinning over fast when theres no load on it is only a test to make sure its not jammed or has a dead spot, doesnt mean it is in good working order.
73c20jim
Sierra Vista, AZ
Good point. It's already out.
SquareRoot
Every single time I've had a "one-clunk ug" it's been a bad connection on the battery cable.
I got so tired of it, especially when working on the truck and unhooking the batt, I installed a master cutoff switch near the batt. Now I lift the hood, turn the switch and instantly kill all electrical power.
No more finiky cable connections.
73c20jim
Sierra Vista, AZ
You got it thanks.
Put brass shotgun brush to cable ends in drill. Starts perfectly not.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
You got it thanks.
Simple fix for the Win !! :waytogo: I assume that like me, you got bit by spell check and that was really starts perfectly now .
Johns C10 Hubcap
