Headlights
87dieselburb
Massachuaetts
V1500
Ok I haven't seen this anywhere I was woundering if there is an aftermarket head light for my 89 burb that isn't the old school glass and metal sealed beam I'm looking for a plastic housing so I can put in hideaways (as this is a plow truck)
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Check E bay. They have all types and sizes of the polycarbonate ( square and round) lenses with and without the led daytime running light option. I found a set of four 4x6 housings for $50 with the led drl's built in.
87dieselburb
Massachuaetts
V1500
I would need the whole housing to be plastic to be able to drill a 1 inch hole for the strobe head
87dieselburb
Massachuaetts
V1500
I wanted to do lights like these but don't I need to do like a new wiring harness or something I don't know someone please help me
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Sounds like you want the composite headlights that are super common all over ebay, amazon, etc.
Get the size housing you want and you'll be able to drill them no problem.
smoothandlow84
Steve
^^^ ×2 E Bay it!
donmateo
WI
You could also put the strobes in just the bottom housing which is all plastic. I will probably do that eventually. Unless the plow covers it?
FenderBanger
