Christian Nelson
- Sep 8, 2011
- Wisconsin
- Christian
- K15
Hi all, I was able to get a 99 pickup with bad 4l65E and cracked fram in exchange for doing some work for a buddy on his "Bleeper" (Jeep Cherokee welded on top of a cut down K20 frame)
I can pull off anything I need, and he will scrap the rest.
My plan is to pull the engine and wire harness, and get a manual transmission flywheel for it, to hook up the SM465 that is in the truck (Unless I can find a NV4500 before I get that far)
I want to do minimal wiring, no need for tranny shifting stuff, as I am planning on keeping it manual transmission.
Need guidance as to what is recommended to pull off donor truck.
I am wanting to change to electric fans, and not use the stock clutch fan on the 5.3.. Will the K10 radiator be ok, or should I pull the newer model radiator from the donor truck?
Gas tank, my project truck (85 K20 with 1/2 ton axles) has no fuel tank currently, previous owner used a fuel cell mounted in bed, should I use the fuel tank from donor truck? Will it fit my truck?
I know I need to use electric fuel pump, and all, and I could just use the whole tank from the donor truck, if it will physically fit. I've heard they are taller than stock square tanks.. Any ideas?
Motor mounts, I've seen Dirty Dingo ones, for around $150 for our trucks. I found these weld your own mounts, they say they are for S-10 swaps. But visually, they look just like the Dirty Dingo ones for squares. I have a good welder, and so forth. I can get these for $37.99, if they will work.. Anyone know for sure if these will NOT work? https://www.ebay.com/itm/S10-LS1-LS...-2-ea-Motor-Mounts-DIY-you-weld-/332749883116
I Am looking for recommendations on who to send the chip to for reflash.
Any other items I may be missing? Any one link to threads on this subject? I am looking for info, especially from those who've gone down this road before.
