Good ignition system?
1987_chevy_
Michigan
Scottsdale
SBC 350
I have a built 383 stroker that I'm working on and am looking for a ignition system! I'd like to stay under $600. It would be awesome if you could give me some of the parts numbers of the stuff you use. Or possibly list the things you put together! Or would a kit be the easier way?
gmachinz
Harnessworx Inc
Iowa
Jabin
I'd say go with a genuine Delco HEI, use BWD Select brand pickup coil, condensor, Accel adj advance curve kit, DUI 60,000V coil and module, then go with Taylor 409 race wire and NGK V-groove plugs. You can easily do this for way under $600 and have a stout OEM style ignition system! One other trick I like to to to provide higher voltage to the coil is to use a high capacity relay to power the coil directly off the alternator charge post and this helps maintain a high coil voltage input.
1987_chevy_
Michigan
Scottsdale
SBC 350
Am I really going to wanna throw an OEM ignition system back in it? I could use what I had if I want to do that? Right?
gmachinz
Harnessworx Inc
Iowa
Jabin
For performance and longevity, you can't beat a GM HEI with a few upgrades. I'm not suggesting this as an armchair builder either-I re-build all of my own HEI distributors....the difference between stock GM and offshore cheap versions is huge IMO.
rich weyand
Bloomington Indiana
Rich
^^^ This.
Georgeb
Wisconsin
George
K10 Burb Z71
If you want to spend a bunch of money on an ignition system you can but a well setup factory HEI will do the job very well.
ACDelco parts all the way is my opinion,
74 Shortbed
ACDelco is just a brand name anymore, unfortunately..
gmachinz
Harnessworx Inc
Iowa
Jabin
Yep...and it's only gonna get worse for parts. GM is importing a fu@king Buick SUV built 100% in China next year I read! As cheap as parts can be made over there-before long all parts will be source from China in the future.
74 Shortbed
Yep, I read that too, it's all going down the crapper..
