GMC-IH
dragstews
GMC-IH
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
I dont understand why you want to overcool your trans and your oil, but the oil cooler idea is less confusing because that wont struggle to be up to temp as much as the trans would
Both the oil and trans coolers have built in thermostats to regulate oil flow through the cooler based on engine temperature, ensuring optimal cooling only when needed.
While that’s good , I would be weary of the quality unless you’re ensuring a high quality manufacturer when you sourced them. I haven’t heard of them so I trust your judgement if you did. Then yes that is sufficient
The basic components ..
1) 4-bolt main Mark IV motor block ..
2) 871 casting heads ..
Now that these are nailed down comes the fun part of the monster motor build ..
(Buying the parts) .. Eek !
Painting the valley is a good way to encourage good oil return. Certainly not a necessary thing but just mentioning
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
After all the machine work has been completed ...
I did use Glyptal on the Mercruiser oil pan ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
This -10 hose should be large enough to allow good flow to the cooler ..
It's from a take-off pile, hoping to see a few more years of life from it ..
are those PTFE lined? and yes, some people try running -6 or -8 when doing oil, but based on the oil cooler line diameters on my gmt800 i always point out they wouldnt use a larger diameter than trans cooler for no reason lol
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Most likely this will be the cooler I'll be buying ..
Has the AN-10 fitting welded on ..
As far as the hose lining, don't recall, do think I bought this hose for a circle track car that had a cooler up front for cooling the rear end lube .. ??
maybe a good idea to investigate if engine oil which runs hotter and higher pressures and different oils overall is compatible, probably is but never hurts to be safe
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Wanted a small, thin LED oil temp gauge to go inside of the glovebox ....
This one was made for motorcycles ..
Perfect for my gig ...
The trans standalone controller is in the box ..
Keeping the dashboard from looking too busy is my aim ...
Pretty dang busy already !!
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Hummmmmm .. ??
Where to locate the oil temp sending unit on the motor ?
My thoughts are to drill & tap the GM cooler adapter ...
Or, be less work involved to install it at the front of the block in one of the threaded ports ..
Be a little more wire to run, but I like doing work the easy way ..
( Beginning to think, in my twilight years, I'm getting lazier ) ... Eek !!
Hummmmmm .. ??
Be a little more wire to run, but I like doing the work the easy way ..
thats what the gmt400 did ,used the port at the front and the extension for the oil pressure sensor
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
That's what the gmt400 did ,used the port at the front and the extension for the oil pressure sensor.
Oil pressure switch is mounted at the port above the oil filter ...
Looks to be in the best spot possible ..
Not in the way of anything ...
I'm looking for a good place to install a oil temperature sending unit ..
Got the LED temp gauge coming, have no idea what the sending unit looks like, but for looking at their photo ...
If it's small enough I'd like to install it on the oil cooler adapter .. It has a pipe plug on the side of it doing nothing but plugging a hole ..
That would be the ideal spot for the sensor ...
Just gotta figure out if it's before the cooler or after ??
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
This gauge is made for Trans oil temperature, I got it on lone just to see how the probe would work on the motor block ..
Looks like it's .....
Perfect spot for the sender, hoping what I have coming has the same threads (1/8" NPT) as this one .... Will make for 'Plug & Play' ...
I see now, i wasnt saying move your oil pressure sensor, (sensor not a switch) but providing a location that receives oil that is in the engine
But youd like to put it on the filter adapter for the oil cooler for ease of access/near firewall? Is that what im hearing?
Ill do some diggin,id think that line is for a pressure tap but see if i can see what its intended for
Edit: The gmt400 had a alternate method of starting the trucks early on that used oil pressure, that could be it too. ill look tho
jw23655
