Getting an 87 V25 C6P HD to sit close to level
GetitBilly
Chicago
Larry
V2500
Anyone know how a C6P truck sat when new? Right now my truck sits a little over 2.5" lower front to rear. Trying to figure out if my stock front springs are sagging before I get 2" lift springs and end up sitting higher in front. Also considering splitting the difference and getting some ORD 1" add-a-leafs, with or without new or re-arched front springs as nesded.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
My '85 definitely always sat higher in the back. It's kind of small in the pic, but this is from when the truck was new:
If you need an actual measurement of how it sits now I can try to do that tomorrow.
K201979
Winona, missouri
Hippie
350ci
If ur going stock height, id get stock springs. Itll probly level it out some. Mine was raked to the front before i lifted 4" and the new springs made it level. If its still raked after stock springs u can add a zero rate to level it.
GetitBilly
Chicago
Larry
V2500
Hey, that pics helps. I'm leaning towards just keeping it simple and cheap and getting the 1" ORD add a leafs. 1" doesn't sound like much, but it will take out a lot of that rake. Based on other pics I've looked at, I think the c6p trucks sat about 1-2" higher in the rear than a non-c6p truck.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That's probably about right. Keep in mind the rear wheelwell openings are lower than the fronts. It can be deceptive sometimes.
imyourhuckberry
