TheSquareGuy
- May 14, 2017
- Montana
- Wyatt
- k10
Ok it started with a stuck selector valve for my gas tanks, that turned into the valve was stuck on a shot tank. I had little experience when I went though this process and didn't think much of this through. I swapped all of the fuel lines from the passenger side of the selector valve to the drivers side. (Passenger tank is completely gone at this point) ok so... The drivers side tank is hooked up as the passenger side. I've got everything wired up (ground is sketchy but not the problem suggestions on a sending unit ground would be appreciated (wire for ground was clipped)) ok so since everything else is hooked up to the passenger side of the selector valve I wired the (this is where most of my knowledge goes downhill) I wired the drivers side wire into the passenger side on the electrical clip that goes into the selector valve. Well that didn't work, gas gauge is still non functional. I red online somewhere that if you wire your pink (from the clip going into the housing of the gauges) directly to your tank the gauge will work??? So here's my question 1) is that gonna work, have any of you tried this or dealt with this issue 2) I'm colorblind so I need to know which number on this clip is the gas gauge (can't find it anywhere)
Please and thank you for help
Sent from my SM-G900V using Tapatalk
