Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
Is it possible to remove the weights from a g80 setup and make it open?
I know it'd be easy enough to find an open carrier, or to find another posi unit or something to swap.
I'm looking for cheap options, not so much a g80 rebuild, and without ebing able to travel or find junkyards close finding one isn't that easy. It's also not cheap, because why would I buy an open carrier, I'd want posi.
I'm only looking into if it's possible to emove the weight and such, in a gov loc g80 to make it open. AND be safe to drive that way.
I'm worried the old g80 we have may be going out, and I have another complete rearend to replace it, thanks @bucket for that.
The reason I ask is because dad's 84 c10 has a 273 g80, and my trans am of course has an 8.5 as well but it's open and has 2.56's, well I want a better ratio, like 3.42's or so for the TA. My thoughts were remove the g80 weights from his carrier, only because the weights are what I'm guessing come apart and tear things up, and then put it in my TA housing so I can bolt on some 3.42's or so.
Of course I may end up finding a 3.42's posi setup somewhere adn use it but just for the hell of it wondering if it'd work or if I can make it work.
I saw one video on youtubr say to just remove em and be done. I also saw on some forums one guy saying for a 14b or so he added some clutches and some preload springs and such to make it like a posi. That would be awesome.
Anyone ever messed with one and tried to remove those weights and run it? If not I may tear into it when I swap dad's rear ends out and see how it goes.
