Fuse box power tap for power windows.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I’m installing power windows in my Olds. I build a ATO fuse box and wiring harness years ago using a square body fuse box. I would have swore I saved the power window plug in harness from the donor truck, I figure as soon as I get a replacement I’ll find it.
The power window power tap snaps into this spot in the fuse box, then the circuit breaker plugs into the power tap. The power windows plug into a pigtail coming from the snap in plug.
This fuse box came from a 83 truck, I think the are used across all the model years with the ATO fuses.
The 81-87 G body cars also use the same plug. Thanks
Ken B
indiana
ken
Good Information. I am using donor power doors on my truck.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Power door locks require power at all times to work, they plug into a different cavity on the fuse box.
The one I’m looking for will have a heavy gauge pink wire (probably 12 gauge?) about 8 inches long with a gray plug on the other end. The power window harness plugs into the gray plug if I remember correctly.
KAR1130
