Fuel tank help
ARtreehugga
Arkansas
Jake
I recently purchase a started project truck. Truck has 6" suspension and 3" body lift. Im lifting the fuel tanks and have some questions about fuel lines. There are two fittings on the top off the tank. One is larger than the other. Which is which? is one a vent or something?
Thanks
Jake
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Welcome from a fellow member from Arkansas. Im in Lincoln btw. Yea the smaller one is the i think a return from the fuel pump/vent and the bigger one is supply to the pump.
ARtreehugga
Arkansas
Jake
Thanks man that's what I was thinking
ARtreehugga
Arkansas
Jake
Ok the passenger side tank is hooked up and working. But the drivers side doesnt have anywhere for the return line coming out of the tank to hook to? Is it nessary to have a return for each tank, or will it return to the passenger side tank when i using the drivers side?
Swims350
Logan WV
none
if it has 2 lines one may be return and not vent, if not then most likely it don't need it.
I never owned a dual tank so I have no clue, but you don't see many ppl fabbing gas tank with only one line or soemthing unless it's plugged and clearly seen like a hose and bolt with clmaps that's easily fixed.
bravo on raising the tanks, body lifts are ok if you don't know they are there, like raising the bumpers, gap gaurds in the wheel wells and then the tanks on these trucks for sure.
ARtreehugga
Arkansas
Jake
Yea on passenger tank i have one hose running to the fuel pump, and the other hose running directly to a line running up the frame. On the driver side tank, I have one hose running across the truck and into the fuel pump, but cant find a spot for the other hose to hook to? Im not familier with these gas tanks at all. The tank on the passenger was hooked up when i got the truck, so i know its right. The drivers side tank was sitting in the bed, so im not sure?
Anybody have any knowlege on these duel tank set ups?
smurph20
Brad
OK on my 86 my left tank had a supply return and a vent that came from the front but the right only had a supply and a return. Both supplys and the returns went through the valve. The only vent went straight to the left tank. I didnt trace it but im sure it went to the charcol canister that on my truck has been removed by the previous owner.
Guardian
Jeff
c 10
Yeah smurph, the vent goes to the canister. The other lines route through the switching valve.
The return only going to one side will not prevent it from working, however, it can cause problems if the right side happens to be full and is getting the return from the left.
smurph20
Brad
Well that explains why i have open lines under my hood then cause my canister was removed by the PO
mick84
