Fuel pump, sending unit grounds?
hoagster
California
K10, 1500
5.3l
Getting ready to run wire from my new tanks? Question is do I run the ground wires all the way to the cab or just to a good spot on the frame near the tanks?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
On the fuel injection trucks, ground strap runs on drivers side frame rail.
Like directly behind the rear wheel
Frame should be grounded to body, frame to motor, motor/frame to battery
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Here's what my '85 looks like. Black wire on the right tank is the easiest to see. It has a star washer where it bolts to the top of the frame.
Hard
