Front turn signal wiring issue
Eighty5ov
Canada
Ov
c15
My left signal in the grille of my 85 seems to be wired wrong, I can’t get it to blink but will turn on with running lights. Any electrical specialists out there that can point me in the right direction ?
350 w/203
Correct bulb (1157)? Dirty contacts? Also check the left rear.
Eighty5ov
Canada
Ov
c15
The contacts are a bit corroded. Would that make it do that ? It was almost like a wax
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
That wax was probably grease at some point. Have you changed the flasher? Was it working in the past?
yes. especially since turn is probably the brighter of the two filaments ( i assume dual)
Eighty5ov
Canada
Ov
c15
I bought the truck last year. Changed the bulb recently. It comes on when I pull the light switch all the way out. But doesn’t blink. Doesn’t come on on the first click of light switch with the others.
sounds to me like a switch, ground, or socket issue most likely. The same wire that powers it in park should power it in headlamps(its doing the same thing) and all I can say is you should check your grounds chassis to engine , chassis to bat, bat to engine, chassis to frame. etc
also, you should show us your socket with the bulb removed
Whats your side marker do when you use the turn?
Also the bulkhead connector.. even if it wasnt bad Its worth pulling them and using contact cleaner and new dielectric grease on them. mine was BAD lol. I believe all those functions route through there(I think)
Eighty5ov
Canada
Ov
c15
Fixed thanks everyone
hauto85
