Front drive shaft splines showing?
Brysonsproject
Washington
Bryson
Chevy K20
Im installing a 4 inch tough country ez ride lift on my 1978 chevy k20. It has a double cardan 2 piece front driveshaft and after installing the new springs, the splines are barely showing where the drive shaft slides into itself. Is this okay? its moved quite a bit from where it was riding at stock height
Also, I installed the rear springs first and the height to the fender well went from about 36 9/16" to 43 3/4". Basically 7 inches of lift??? Could this be because the old rear springs were so fatigued that they lost 2 or 3 inches and the ones I just put in aren't relaxed yet? I've heard that with a 4 inch lift, I shouldn't have to do any work lengthening the drive shafts, but from all this lift, I''m worried I might have to. Anyone encountered this before? Also thinking I might have to check to make sure they sent me the right springs based on their part number.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
4 inch rough country lift, put 30,000 on it, didn't have the splines rebuilt the first time because it didn't need it. They need it now.
So I had my front shaft lengthened 2 inches, I would say it's a half inch too long about, maybe just 1/4. It still clears just fine, I just fear with the right flex and then a good compression on that side it may bottom out. But I've had no issues in a couple thousand miles since I had my other shaft lengthened.
When I do it again I'll probably just do an inch and a half, for a four inch lift. Long story short, you'll be okay, but for longevity I would lengthen it. I paid like 280 for a full rebuilt shaft and lengthened.
Also yes the springs tend to sag quite a bit, my suburban is around 4-5 inches lower in the rear because of the leafs sagging.
Also don't mind that paint mark, that's not how much it actually travels
87gmcburb
Don
GMC Sierra Classic Suburban
Also, I installed the rear springs first and the height to the fender well went from about 36 9/16" to 43 3/4". Basically 7 inches of lift??? Could this be because the old rear springs were so fatigued that they lost 2 or 3 inches and the ones I just put in aren't relaxed yet? I've heard that with a 4 inch lift, I shouldn't have to do any work lengthening the drive shafts, but from all this lift, I'm worried I might have to. Anyone encountered this before? Also thinking I might have to check to make sure they sent me the right springs based on their part number.
Had the same issue with my 84 burb when I lifted it. I ended up taking my front shaft in and having it lengthened. If you run it too long in 4 wheel with it not fully "seated" it can eventually waste the splines. As for the rear springs. they do get fatigued and will lose height, that sounds like a lot though. I always replace all four and lengthen the front shaft whenever I do a lift on a 4x4
Did you torque the front spring hanger and shackle bolts with weight on the front end? If not, that may be part of your excessive lift amount.
As for the shaft, you'll want to make sure it's at least long enough not to come apart when the RF wheel goes to full droop. Jack up the LF wheel (by lifting under the axle) until the RF wheel starts to lift from the ground, then see if the front yoke on the shaft can still reach the yoke on the diff. If it can, install it and grab the shaft tube near the splines and see if it has a bunch of slop in it. If so, the shaft will not live long at all without being lengthened.
ali_c20
Austria
Alexander
C20, K5
Depends one the use. If you need your 4wd only sometimes in winter or on dirt roads you could leave it as it is.
If you drive offroad a lot lengthen it. my 0.02$
FenderBanger
