Rustywer
- Jul 8, 2014
- San Diego, Ca.
- Rusty
- C30
- 350 CID
So I've posted twice before with no response, and I have just about had it with this 77.
Long story short.....
350, blew the headgasket. Reworked 822 heads, reman distributor, new fuel pump, and it falls on it's face under load.
Have the distributor, I believe, 1 tooth retarded but used the old vacuum guage timing set and have it at max vac (20" at idle 650). Vac will drop if I retard or advance. Idle is fairly smooth with a slight pop from the exhaust, but the air injection is on ported vacuum and the valve was recently freed up with a little clean and lube. Cam looked good when i had it apart and the pistons are .030 over. This motor was worked about 60k miles ago and the bottom end looks ok. I have the valves at approximately 3/4 of a turn past zero lash. The quadrajet adjusted out ok, and unloaded (REVVING) the secondaries open and response is good.
The issue is that as soon as I put a heavy load on it (towing) it comes up ok in 2nd then goes flat when i shift to third and will not climb even a slight incline and heats up to just into the red on a stock temp guage. Even without a towing load, performance drops off as it heats up to 3/4 deflection on that same guage.
I won' say that there aren' t any vacuum leaks, but spraying carb cleaner at the base of the intake will only cause a very slight deflection in idle.
I'm really frustrated with this little project. Right now i have about $4500.00 invested in this thing, and a wife who loves to remind me that she said "Don't buy that truck" PRIDE GOETH BEFORE THE FALL I GUESS.......
Any help would be appreciated.
