Flexible brake line hose removal??
81C10
South Carolina
Mark
4.1L Inline 6
How would one take the flexible brake hose out of the frame? It's original brake line on 1981 C-10 2wd. Everything I've seen says something about a "C" clip holding it in, but it appears that mine has a flat washer. It looks like it would unscrew form the frame but that isn't working. Any suggestions? The hard line came off no problem....once I got a set of Flare nut wrenches,:drool:
Trying to fix a sticky CALIPER on the driver side. I replaced the Caliper with a re-man unit from parts store, and that didn't work. So only other option is the flex line collapsed on the inside, right? At least that's what I narrowed it down to. Passenger side works fine.
Any help would be appreciated, thanks....
robracing85
