Factory AC compressor hose connection
texasmike
Conroe Texas
I had the R4 compressor replaced with a new ACDelco unit and it is slowly leaking Freon at the double hose connector. It is held in place with a single bolt and has two O-rings. It looks like one is red and the other is green. Is that correct or should they both be the same color and type?
Snoots
Roger
Jimmy Sierra
350 w/203
Both should be green and coat them with compressor oil.
fast 99
Spokane, Washington
Some of those compressors take a different thickness seal between the pressure and suction sides.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
You may need the crackhead AC Delco sealing washer chart, if you have a newer hose set or a compressor without the relief for the big o-rings (which were universal for decades).
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I've got a new hose set and a very late Dephi service compressor. I had a pic where you could see the washer colors, but I can't seem to find it. I want to say I needed a yellow and green. Getting the manifold flat against the compressor is the object of this exercise.
Dons79C10
