Engine runs rough and backfires after warm-up
wheelie-schizes
Germany Göppingen
V 3500
454 7,4L
My 454 TBI starts and idles low, but after about 2 minutes (once it warms up), it starts backfiring through the air filter and won’t take throttle.
Here’s what I’ve done trying to fix it:
- Replaced spark plugs, wires, ignition coil
- New distributor (installed by someone else)
- New fuel injectors and fuel pressure regulator
- Also found the EGR valve was loose and leaking — I resealed and tightened it
Timing is set to around 4° BTDC, but it’s hard to adjust properly because it seems to shift on its own.
There’s no vacuum advance on the distributor, so I assume timing is electronically controlled.
**Do I need to disconnect the timing advance wire when setting base timing?**
Any input or ideas are appreciated!
Yes you need to disconnect the set timing connector. When,how and why did it start backfiring? Have you actually checked fuel pressure?
Okay does it run okay cold? Cold it's in open loop. Warm it's in closed loop,I'd start by testing my sensors.
clee
