militaryjeep
- Mar 4, 2020
- chatsworth
- steve
- Suburban K20
Basics:
1986 Suburban K2500 350 "M" code Federal emissions, Originally TH400 and 208 Transfer
I bought this super clean rig with the remnants of the take out engine in the back.
Was all a bunch of mismatched worthless stuff.
I located a take out 1985 crate engine that only had 10,000 miles on it but
low compression on 2 cylinders. Turns out it had 2 burned valves.
Got that all back together and located all the bracketry and smog equipment
required to stay legal in Kalifornia.
Upgrading to a 4L80E mated to the rebuilt 208 transfer.
Now the burning question:
Do I install the engine by itself and then lift the trans/transfer up from underneath
or bolt it all together and slam the whole thing in one shot?
I have a forlift and a heavy duty tiltable engine sling. I have used this setup
for changing the powerplants on Humvee's but they were designed for the motor,
trans and transfer to come out together.
I was thinking to pull the front core support, radiator and AC condenser and slip
the whole thing in, I have the motor all built up on the stand all the way
including the stock header type exhaust manifolds.
Anybody attempted this before? My guess is that is how it went in the chassis
at the factory but they may not have had the body married to the frame at
that point on the assembly line.
Looking for advice!!
