Engine cranks, but no start. Unsure of the problem.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
Dudes..i played Eddie Rabbit and everything!
Dunno why he ran away but it's regrettable.
NOW WE'LL NEVER KNOW! :(
Sad Sack
Nebraska
Goober
C15
@Cj1234
Please post an update, cliffhanger theater is killing us.
JBswth
Vallejo, California
James
C25
292 cubic inches
I have a 78 Chevy c10 with a 350 rebuilt sbc in it. Engine cranks very slowly but never wants to turn over. I messed with the firing order and distributor before this problem, I fixed it and made sure everything where it’s needed to be. I’ve double checked grounds, they’re good. I have a feeling that it’s my starter but again not sure. Everytime I crank, it’s slow, and my battery will drop down to 9v. Also when I crank and spin the distributor it sounds like it’s about to start but doesn’t. What else can it possibly be? Anything I should look at?
The fact that you just installed a fresh engine says that the first thing you should check is if the engine turns freely or not by hand. Sounds like you might have a tight bearing or two. If it doesn't, you need to pull the pan and check each one, one at a time. If any are tight, it will be obvious by looking at them.
J. B.
Nborden88
