electrical
ice205
montana
lee
1985 chevy
suburban
ok ive checked all my wires .battery is new ..altanator new .....ive rewired many times and checked with meters ..after a few days if i let my truck sit like 3-4 days battery is dead ....? can the regulator in the altanator be stuck to where power would be lost ......? hell im to the point of just stripping out the truck if i cant get this fixed ...
77 K20
Montana
K20 5" lift
HT383 fuel injected
Do you have a digital multimeter and do you know how to check current?
Put the meter on amps and then disconnect the + battery cable. Hook the meter in series. How much is the draw? Then start unplugging fuses and see if it drops to 0.
I'd start with aftermarket stuff first. Car alarm? Aftermarket stereo? Amplifiers?
There are getting to be more and more people from MT on here. Maybe eventually some will be less than 400 miles apart...
Here is the procedure I use to isolate a battery drain. Remove negative battery cable from the battery. Using a 12-volt test light (make it up with alligator clips on the leads), hook one end to the negative battery post the other end to the negative battery cable you just disconnected.
BTW - this procedure will be much easier if you use nice long leads for the test lamp. That way you can keep the lamp right near you as you work (more on that later).
The test light will glow or “light” if there is a flow of electrons through the battery. If the “light or glow” is faint, that is normal. The battery is supposed to supply a minimal amount of power at all times to several components. For example the clock, radio or computer.
So, moving on, if the test lamp is bright, then there is a large drain. That is what is killing your battery overnight (or within a couple of days as is your case) - and it needs to be corrected.
Now, with an eye always on the test lamp, start removing and replacing the fuses one by one. When the light goes out (or dims considerably); that will be the circuit with the drain. WHEN YOU FIND THE AFFECTED CIRCUIT, LEAVE THE FUSE OUT.
Read the fuse box cover. If the circuit is providing power to stuff you can live without for a while (directionals, horn, radio, etc.) don’t do anything else right now. Just remove your test lamp rig, put the cable back on the battery and use the truck as normal. See if the problem is solved. If the battery can now hold a charge overnight – well then, you have identified the problem circuit.
However, if it is a vital circuit (fuel pump, headlights or wipers), or you if want to fix it right away, go to the next step.
Easy so far right?
Now, once the circuit has been identified, comes the tough part. You need to identify whether the drain is in a component or somewhere in the connecting wires. This trick will make it easy to find the ground (and trust me it will be a ground fault as opposed to a short circuit ).
Now, I say it will definitely be a ground because if it were a short circuit you would have had to deal with this long ago. At this rate of discharge, you would have most likely been blowing the fuse that feeds the circuit.
So, take the test rig that you disconnected from the battery post and cable clamp and remove the alligator clips from the ends of the leads. Take a couple of tiny male spade type solderless connections (Stakons) and crimp one to each of the two test lamp leads. Plug these into the fuse holder just as if they were the prongs of a fuse. Or, places like Autozone sell a special fuse that actually has leads that you can you can attach things to. However you do this, make it up well and secure it tightly so it can’t get yanked out.
The test lamp should light up just as brightly as when it was attached to the battery.
Now look in your owners manual (sometimes it will give more detail than the fuse box cover) and see what things are driven by this circuit. Then, while dragging your test lamp around with you (see why I said to make it up with nice long leads) start disconnecting things one at a time. As you do this, leave the component disconnected.
This is basically the same procedure as we used to find the faulty circuit – we are now just dialing in as to exactly where within the circuit the problem lies. Watch the lamp at all times, when you pull the connector off of the right thing the light will dim and you will have found the bad component.
Repair it or replace as necessary. Plug everything else back in too. Check your work with the lamp.
Okay, what if you disconnected everything single thing in the circuit and the lamp is still bright? Either your owners manual is not providing enough detail and there are other things still connected to the circuit or, and this sucks- it is in the wiring.
If it because there is still something plugged in that the manual (or fuse box) doesn’t mention, get the appropriate wiring diagram/schematics and ring the system out.
If it is in the wiring, again here is where the long leads come in handy. Pick one component and, starting from where it mounts, begin wiggling and shaking the wiring bundle (always watching the test lamp), working back towards the battery. It will take some time but eventually you should see the bulb dim. Play around with the wires in that area, open the bundle carefully with a sharp knife, pull on them, twist them, do whatever you need to do to find the ground.
But always remember we are looking for a ground to the chassis not a short circuit between two wires. So pay special attention in areas where the wiring can touch the frame or where it passes through a tight penetration.
Good luck. There are other methods to find a buried ground (the smoke test for example) but they are for professionals only. But with any luck, these methods should find and repair your ground.
ice205
montana
lee
1985 chevy
suburban
anything running would be the factory clock and my memory for the radio....everything else is disconnected ............thx all
If you have stripped the board and still have a heavy key-off drain, check the 3 main leads for short to ground. Pull/cut the connections to:
1. The junction block on the firewall
2. The field excitation to the alternator (small red lead connected by the plug)
3. The alternator output (big red lead connected to the stud under the boot)
If you still drain the battery, the short is either in one of those red wires (between the solenoid and the JB/alt) or in the main cable from the battery to the solenoid.
And, to kind of answer your question; can the regulator in the altanator be stuck to where power would be lost? Yes - the diode set can fail to ground and cause the battery to discharge.
Dons79C10
