educate me on "roller cam capable" blocks
1low4x4
Nick
Here the 350 I pulled out of my newly aquired blue 85. Rod knock.
This block has three drilled and tapped holes in the valley. That means it can use a roller cam? What exactly does this mean? What are the benefits to a roller cam? Worth all the fuss?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
That may even be a newer goodwrench replacement. Yes, it is roller ready, all you need is th cam, lifters and retainer plate.
You can go with a little quicker(shorter duration) cam, which is good for low end grunt, longevity, and less friction.
Put an HT383 roller cam or an lt4 cam in that bitch, and look the **** out!
MrMarty51
Eastern Montana
Martin
OK,on the subject of cams.
That is a TBI block,are they all bossed/drilled aand tapped for the plate ???
What would be the best cam for up to around five grand,mostly around town with some pulling heavy loads on a 7,000 pound tandem axle trailer,mostly cars and pickups with the ocassional farm tractor that`ll really load things down.
I like the fuel mileage I am getting,on a bad day is 18 per,if I could get real good grunt and incrfease the fuel mileage any whatever,that would be a bonus.
Jims86
Patterson,Ca
5.7 TBI
There will be a trade off. I would jump up to the next lowest gear ratio first. I had no problems buzzing my TBI up passed 5000. HT 383E cam would be the way to go though.
MrMarty51
Eastern Montana
Martin
OK,that`ll be what it is then.
248,000 miles and still running strong,I will rebuild this block and these heads when the time comes,for now I am scrounging and gathering parts for that day.
Thank You very much.
Jims86
Patterson,Ca
5.7 TBI
remember it has to be the E cam, which is designed for EFI.
Driver4r
Nebraska
Trevor
k10,c20
There is no "Roller cam block" They make a roller cam for almost any real popular engine(sbc,bbc,etc....).
Jims86
Patterson,Ca
5.7 TBI
Valuable info there....
We are speaking of the pre drilled/ tapped blocks, and what is considered roller ready.
Driver4r
Nebraska
Trevor
k10,c20
Thanks, i teach the world.
But many people dont know that really any block can run a roller cam.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
What heads are they? Most smog ETA heads don't work well over 4k.
Jims86
Patterson,Ca
5.7 TBI
Jeremy! Dafockyoubeen?!
LT 4 cam pulled pretty good to 5300 with TBI heads, with some exhaust side porting.
I don't think that's the issue. It's A LOT cheaper to run a roller cam in a "roller ready" block, and IMHO, the factory setup is more reliable too.
Squarebody322
