Dual Tank Question
1981lowrider
Seminole,OK
Jack
Sierra
V-8
I have Dual tanks on my 81 shortbed. i was told the passenger side only worked. I got a new selector valve and it The dual tanks still doesn't work. My question could it be the Switch itself the one on the dash? Or is there something else? Just want to get both tanks working. I searched the threads for this topic but couldn't find anything. Any help is appreciated!!
hirschdalechevy
norcal
rich
k-30
Could be the switch on the dash. One time on my 77 I put in a new dash switch and valve on the frame and I still had nothing , it turned out that the valve on the frame was not grounded well , (to much paint) , so I sanded some paint where it mounted and put it back on good to go.
Also check all your wireing
Also you may want to check the other tank if it has been not used for a long time , I have seen the sock at the pick up tube totally plugged off before
78shortandwide
Denver
Tom
I've had more than one switch go out id check it first.
1981lowrider
Seminole,OK
Jack
Sierra
V-8
Ok Guy's, I bought a new switch today will let you know! If that doesn't fix i will check the wire, Thanks for the help!!
1981lowrider
Seminole,OK
Jack
Sierra
V-8
Got the switch in , and it fixed it!! Thanks for the help !!
atp fab
