86k20-ds
- May 30, 2026
- arizona
- geoff
- K20 Custom Deluxe
- 5.7 Liter 350
So… I got myself into a pickle. I was replacing the door hinge pins on my 86 and that went fine, got the door bolted back up. When I closed the door and tried to reopen it it rubbed on the fender badly and wouldn’t open, which made me realize that I didn’t bolt the door back on perfectly. This then changed the gap on the door causing the door the hit the fender and not open all the way. It doesn’t open enough to get to the bolts to fix it, so what are your suggestions? Any input helps
