Door jamb switch
silverscottsk10
trafalgar indiana
mike
How is the switch wired?
I want to take one out of my parts truck and made it work so that when I open my toolbox and it lights up
My trouble is how to wire that switch
Moderator Administrator
So you're not wanting to turn the dome light on in your truck when you open the box right? You're wanting to put a light in the toolbox and have it work off the switch???
If that's the case, you'd add a hot wire to the positive side of the light, then from the ground side of the light, take a wire to this switch. When the door opens, the switch will ground the wire and the light will come on.
silverscottsk10
trafalgar indiana
mike
Exactly
I've about 10' of white LEDs and need a place to use them
And my cargo light doesn't work when the lid on the box is up
Thanks
I'll get it all hooked up after I get the switch from home
Hoodbj
Billy
That's a good idea, I just built a bedcover and was thinking of putting led lights under it, didn't think of a normally closed button though. I will be adding this to the "to do" list on the ole truck.
silverscottsk10
trafalgar indiana
mike
I was trying to find them on eBay but it never said nc or no
So I'll use one from my parts truck and maybe put one under my hood too
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
Is automotive wiring backwards from household? I'm used to going hot-->switch-->light-->ground.
Hoodbj
Billy
I'm not a wiring expert by any means but I believe you can break either the ground or the hot as long as the other is direct. I'm sure there is a good reason for breaking the ground (shorting/arcing) that I'm not smart enough to know
Lots of foreign cars do **** backwards, but in these trucks and many american vehicles, the door jamb switch just completes a ground to the chassis for the interior lights to come on.
Hoodbj
Billy
I do know that auto is different from home in the aspect that in automotive black is normally the ground and in home wiring it's hot , don't mess that one up or bzzzzz.
I'm sure the reason that door jamb switches and dome lights are wired this way is so that you just have hot to the lights, then don't have to run hots to all the door jambs, and all the door jambs are natural chassis grounds, so it mean running alot less wire too.
Hoodbj
Billy
Makes sense to me hr, one smart honcho
silverscottsk10
trafalgar indiana
mike
Those little bastards are 8$ a piece lol
I guess I'll wait until I make a trip back home and steal them from the Scottsdale lol
Where is trafalager? I know someone that just pulled 4 of them out of Suburban. :shrug:
silverscottsk10
trafalgar indiana
mike
Trafalgar
Lol
Raglafart backwards
And bout 45 minutes south of Indianapolis
Trafalgar
Lol
Raglafart backwards
Ahh OK, so you're in the states. You might want to change your Location and put IN. Many times members might have parts, or swinging thru town so it might help you to let everyone know. How many do you need? May not be that much to First Class mail them.
crowe-t
