Do I pull engine or tranny?
cramezl
Oklahoma
Here's my dilemma. I keep going back and forth on whether to pull my engine or tranny to solve my problems, which are:
Leaking rear main
Leaking valve covers
Leaking oil pan
Bad clutch
Power steering leak
If I pull the engine, I can fix my clutch and have room to fix all the engine stuff outside the truck. Otherwise I can just pull the tranny and fix the leaks in place. What would you guys do?
Sent from my HTC Hero S using Tapatalk 2
BowTieJockey
Tallahassee fl.
Trey
Engine because fishing the oil pan in place while the engine is in the truck wouldn't be fun
Posted from my phone in my lap during class
Just pull both at the same time IMO
Stewzer55
Ohio
Stew
R30
Pull them both and clean up your frame while you're there.
cramezl
Oklahoma
The frame is pretty clean. I was trying to minimize the number of parts I have to remove to fix my problems. Removing both engine and tranny is not ideal
1low4x4
Nick
I'd pull trans. Much less work to pull. No exhaust to mess with, no real harness, radiator and fan and hoses....
All you'd pull is trans lines, bellhousing bolts and trans crossmember. Linkage. Driveshaft.
And the t-case.
BowTieJockey
Tallahassee fl.
Trey
Yea but pulling oil pan off engine while its in the truck isn't imposible but wouldn't be easy especially going back in with sealant on it
cramezl
Oklahoma
That is one of my main concerns. I hate redoing a crappy gasket job because it didn't seal the first time
robert8096
Goose Creek SC
Robert
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Honestly, it's going to be a ton easier to remove both at the same time. Pull the transfer case off of the back of the trans, and pull the engine and trans together. Oil pan is easier to get to, and you don't have to align a clutch, and then an entire trans while listing on your back.
cramezl
Oklahoma
I know the trans is short, but is it small enough to come out attached to that monster 350????
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Neither of them are really very big.
cramezl
Oklahoma
Haha yeah that monster 350 part was a little sarcastic. I actually didn't think about leaving them attached. That might be the way to do it. I was a little concerned about aligning the clutch parts
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
I'd pull the motor, If it was me. More room to fix those leaking issues and have some elbow room.
cpender
