Do I have a column or cluster problem??
Ypsik10
Ypsilanti mi
Chad
New to the forumrestoring a 79k10 my problem is ... My brights indicator in my cluster are stuck on along with the turn signal lights and not all the lights work(all bulbs replaced) wen I bought the truck the turn signals worked and that was it I took cluster apart to polish the lens and replace bulbs now having the above problems is this an issue with the actual cluster ?? Also the wiring harness that plugs into the cluster (with all the prongs on both sides) all those prongs on both sides do not have power wen tested with a light tester wen key is in on position... Should they?? Thanks for any help!
RangRayy
Kansas City, Missouri
ryan
r10
Check the blinker relay or flasher under the dash on the fuse box
Edited flasher not clicker
Ypsik10
Ypsilanti mi
Chad
Ok thank you I'll try that tomorrow
C20NamedWaylon109
