dimmer switch
bonanza_rambler
central city ky
ben
1976 & 1986
C10 & K10
406 & 350
has any one changed a dimer switch on 86 k10 with cc...kinda wanting to know what kinda job it is?
J Knight
Baytown TX
82 Chevy
350ci
Not bad, its on the upper left side of the steering column next to the ignition switch.
Part of the multifunction switch inside the column isn't it???
Nope, when you pull the lever, it pushes a rod that engages the dimmer switch that's mounted external on the column. It's adjustable too, and sometimes that's the only problem. I've also found that if the switch isn't used for a long time, it can actually get a bit stuck. The switch in my '84 started working after about a year of trying it every now and then.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Ha.....didn't know that. Good info once again Bucket!!
FenderBanger
