Digital Torque Wrench - Member Special
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: gmsquare
Our Torque Wrench makes a great Father's Day gift - so don't miss out!!
You can see the torque wrench in action in the following video:
Brown Line Metalworks Digital Torque Wrench - YouTube
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until August 1st, and is only for the lower 48 states.
oneluckypops
Sedalia, Mo.
Luke
Maybe I missed it, but what kind of Warranty are you giving on it?
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. We have a repair/calibration in Chicago in case anything does need to be done to the wrench.
BLMW
davbell22602
Bunker Hill, WV
I Dont
Have
One
Do you have this in 1/4 drive in 300 to 400 inch pounds?
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
Father's Day is coming quick. Don't miss out on a great gift!
Just for you guys suggestions and marketing for other products, I'd be more interested in a 3/8's drive that could inch pounds pretty low. As of now, I use an old school bar with needle type for building automatic transmission where many torque specs are like 12 ft lbs. To be more accurate to a scale, rather than use a 1/2 drive at 12ft lbs since it's so low on the scale, I use an inch lb, multiply 12 ft lb by 12 inches to give me 144 in lbs and I torque to 150in lbs. That has worked well for years. So maybe work on a 3/8 drive model with a lower scale than the 1/2 drive.
Where is this item manufactured???
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
The steel components and ratchet are from Taiwan, and the assembly and electronics are done in Malaysia.
BLMW
blmw
Preferred Vendor
Preferred Vendor
Chicago
jimmy
na
NA
na
Really appreciate the suggestion. We are currently working on a full line of wrenches, which will have a 3/8" and a 1/4" drive in the lower ranges that you want. Should be available next year.
BLMW
BLMW
Cool, I may need it by then. The old bar and needle still work, but I've had to bend the bar a couple of times from accidents.
guillermoariast
