Difference between dashboards
uprising
Germany
Charly
Hi guys,
i would like to buy a new dash bur don‘t know where are the differneces. I have a k10 with a wrong Vin but it should be from 1975. At LMC i saw that there are dashes for the year 75-77 and 78-xx. Can someone tell me the differences?
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
75-77 doesn't have a hole for the vin number as the vin is on the drivers side latch post
uprising
Germany
Charly
Do you mean the Vin in the dashpad?
I mean the dash bezels. Sry for the wrong input!
Big Chip
Michigan
Kevin
C35
I believe the wiper switch and maybe the headlight switche are in different locations.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
75-77
78-80
Big Chip
Michigan
Kevin
C35
I stand corrected but they certainly aren’t the same, are they?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The only difference I see, besides lighting, color and angle (and the presence of the plastic knockout in the top right and bottom left) is the printed lettering for volume and selector over the radio knobs.
uprising
Germany
Charly
I called LMC and they said that there are some differences in the style but they can‘t say if there are differences in the dimensions. I think i will take the 75-77 and keep my fingers crossed! Thanks guys!
If you have the two in front of you, they are styled very differently. The wiper switch hole is in a slightly different location too.
So does your dash have a VIN on it? That will tell you the year of the cab, and what dash bezel will likely be the best fit.
uprising
Germany
Charly
My VIN is also located at the door post. I ordered the one till 1977 and i hope it will fit. It sucks to not have the correct Vin...
Big Chip
Michigan
Kevin
C35
I take back my “I stand corrected” and issue an “I told you bitches the wiper switch hole was different”.
Shak379
