Diesel Fuel Tanks
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Has anyone taken the diesel fuel tanks, cleaned them, and used them for gas? I'm switching from diesel to gas and have dual tanks.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The tanks are the same, but the pickups are different. Just drain them, change the pickups and put gas in.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Thanks. I haven't removed them yet. The truck has sit for many years.
80BrownK10
Greenwood, SC
Nate
I wouldn't even worry. I'd just drain one and fill it. I'd even fill it with gas if it had a few gallons of diesel left in it and run it. Unless you have some super high tech built motor I wouldn't worry at all.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Got the passenger side tank out today. Was dry, no fuel. A few rust spots. Will put some fluid in it to see if it leaks.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Removed the drivers side tank today. Has about 5 gallons of fuel in it, and no signs of leakage.
Has anyone modified the fuel lines going over the frame on the drivers side tank? I'm thinking about extending the rubber fuel lines to go over the frame and then connect to the metal lines, just for ease of installation and if they ever have to be removed again.
Can the diesel pickups be used for gas?
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Both tanks turned out rusted through with pin holes. first pic is the passenger side, second pic the drivers side. They had the plastic coverings on them.
80BrownK10
Greenwood, SC
Nate
I think it was quoted for less that $200 shipped you can have both tanks at your door new
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
That's sounds really interesting but I imagine it is ALSO a ton of work!
:cool:
Not really. Had to cut out the diesel wires I no longer needed. Switched to vacuum boost brakes. The hardest part is finding parts that are bad after the truck sat for over 10 years like the calipers, rotors, tanks, u joints, removing unwanted add-ons, etc, or finding SBC accessory brackets.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
DawgmanDew
