Delco Radio Short
Richmond, VA
Andrew
R10
I have the original delco radio in my 87 R10. It looks great and sounds great when it plays. I replaced the wire harness because the tabs looked worn out. So, I figured the connections were not snug. It didn’t fix the problem. Basically if I apply pressure on the side of the harness, pushing it towards the driver’s door, the radio works. I have examined the inside of the radio and see no bad solders. I am a little run down from every problem turning into an endless rabbit hole. Any cheap and easy fixes?
mick84
