Delay wipers in a 78?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I think I saw somewhere that delay wipers were an option in 78 model trucks, is that true? If it is, what all do I need to put them in?
bluex
Spartanburg SC
C15
Yes they are an option and you need the switch and the delay module. The switch isnt hard to find, the delay module is @gmachinz might have a complete setup for you.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
That is true. My 78 big 10 has them
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Such as these?? Lol
dvdswan
Port Orchard, WA
Dave
My switch was bad on mine so I bought a new one, when I when to use the washer the switch came apart. Why is it so hard for a company to make quality products these days.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I just bought the switch for $4 at a swap meet and the switch with relay from the swap meet also, they are gm original.
bigcountry78
James
K10 Custom Deluxe
If that’s the case I would love to have that option for my truck. I always seem to be in a light mist. Just enough to need wipersbut not enough to need low speed.
77 K20
Montana
K20 5" lift
HT383 fuel injected
What is the oldest year delay wipers were available? Was it '78?
Catbox
Peter
C20 Silverado Camper Special
I need them in my truck as well.
That and a tilt column were the only things I wished came in it along with what it has...
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
You sellin?
:favorites13:
If i dont need the relay i most likely will be selling it.. im gunna start with the switch and if that dont change it im gunna go after the relay. Im trying to make my squirters work and my delay work correctly.
Catbox
Peter
Remember me when you are finished with them...
I have to wait another 2-1/2 weeks before I can go junkyard hunting for one.
bigcountry78
James
K10 Custom Deluxe
If he doesn’t want them when the time comes, I’d be interested in that set up. What year did delay wipers become standard?
gmachinz
Harnessworx Inc
Iowa
Jabin
First year for delay was 1977. Unreliable but a pretty rare option for that year. Re-designed in 1978 and carried thru until 1983. Then became a common feature beginning in 1984 when GM moved the wiper switch to the turn signal stalk.
sever
