Dash switch conversion
james C
Ga
James
Jimmy
Ok so on my 88’ Gmc Jimmy(k5) the switch on the dash that controls the rear window is broken and ugly. So I’m going to try and swap the switch for a passenger window switch so I purchased a harness for it and need help figuring out what to snip and what to connect. I would appreciate any information you have or if it’s been done before, Thanks.
Old switch
The female to the switch has 3 wires (blue, red, and white) going to it this is the best picture I got
gmbellew
Kansas city
glen
suburban 1500
check the wiring diagrams to be sure. Based on window harnesses on my suburban, I guess the following.
Pink is for direct power from ignition on source. Black/blue and Blue/white is power and ground from the master driver switch when it is used. Blue and brown go to window motor. The motors on the Windows are reverse polarity - they go up and down depending which way the current flows.
I have no idea if the rear window switch can be adapted to that harness. Good luck
james C
Ga
James
Jimmy
Thank you. I’m going to look into that
Auburn, Washington
Why complicate things when a new proper switch is $30?
james C
Ga
James
Jimmy
Cause it’s fun
jash1990
