dads cammed tbi need computer tuning?
1low4x4
Nick
Hey tbi gurus...my dad converted his 86 c10 from carb to tbi using all the stuff from like a 90s van. He also swapped from a th350 trans to a 4L60e.
The engine has swirl port heads, a large cam (enough to make it lope good-hwve to get the numbers on it later this evening) and is bored .030. Stock converter.
Hes concerned about mileage...he thought that with the overdrive and tbi he would get much better but he isnt...hes getting about the same mileage as with the carb and 3 speed.
He is using the stock computer...does it need tuning to make it run better? Any help is appreciated. Hes pissed that its not doing any better lol
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Stock TBI tune w/ a large cam will run very rich due to the MAP sensor seeing low vacuum (i.e. it thinks the motor is under load).
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Dang ole....yup^^^^^^
Do you by any chance have the cam specs or what cam it be?
How far are you from San Antonio, or do you already know of a dyno tuner close to you?
Did he get a controller for the trans, or is that still in the works?
1low4x4
Nick
I do not have them right now but I will when my dads gets to his house and finds the info on it.
Swims350
Logan WV
none
anytime tbi is not stock or very close to it, tune is in order.
MrMarty51
Eastern Montana
Martin
:emotions33::popcorn::popcorn: Here, have a popcorn and a beer :cheers: while We`re waiting.
:popcorn:
Posted From Hell
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
...a large cam (enough to make it lope good-hwve to get the numbers on it later this evening)....
...Hes concerned about mileage...
:lol:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
tbi does not like big cams you have to stay pretty mild with cams for tbi
gpmorgan
Tupelo Ms.
greg
It will probably be cheaper to put the carb back on it. I hope that's a 4l60 trans. If it's a 4l60e, as mentioned, you will need a controller for it. If it's a 4l60 you will only need a tv cable.
dan86
