timbo350
- Mar 25, 2012
- okeechobee fl,
- timothy
- k20
I have A 91 fullsize blazer 350 tbi 700r4 tranny np 241 case the speedo started acting up along with the brakes so I switched out the speed sensor from one of my spares and everything was fine for about 2 weeks then it happened again so bought a new one didn't fix it my mechanic that I only go to if im completely stumped said the truck has a d.r.a.c module that takes the signal from the speed sensor and distributes it thru the anti lock rear brakes the cruise control and ignition he said it could be bad I pulled it out which all it is a circuit board which didn't look burnt or damaged bad thing is they don't make new ones anymore My question is has anyone ever had a problem with these and was able to fix it?
