Cylinder head identification
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
I'm having a tough time figuring out this engine. My truck originally came with a 292 i6, or so i've figured from the vin. It now has a 350 from 1975 with casting number 3970010. the number on the front of the block is vo722txl from this i got that it is a 185hp van or bus motor. The cylinder head has casting number 3998991 which tells me the valve size but not chamber volume. It also has gm 73 cast right above cylinders 3 and 5. I'm wanting to see what the compression ratio is and whether these heads are any good. Thanks in advance fellas!
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
I forgot to mention there is an upside down t shape underneath the long string of head numbers
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
3998991 307, 350, 75cc, 72-73, 73 had hard seats
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Exactly what I was thinking...Can you see an marksmon the front of the heads, maybe get us a pic?
Most of those heads were the same smog headsnup to 86, which arenthe same heads that GMPP is using on the 290/350. they havenkinda a lopsided trianglemcast on the front of the heads for Identification.
Sachmo
Mishawaka Indiana
Tyler
k20
350/sm465
The front of the head has this shape. The shape is also cast under the valve cover.
mpatton
