Cummins swap
fowjacob
Lubbock,TX
c3500
383 Stroker
Hey guys sorry it's been awhile since I been on the forum I actually bought a 97 cummins and was driving it because the square body's tranny went out. Well Monday night on my birthday I rolled my cummins and destroyed the truck me and my girlfriend came out with just minor scratches! But now I don't have a truck and am really wanting to put the cummins in the old crew cab!!
I'm wanting to run the nv4500 that's in the dodge and trying to keep the 241tc! As we know that driver side drop! I was also thinking about putting the dodge Dana 60 coil over under the Chevy also what do y'all think? I believe I have most the stuff needed to do the swap just need money to get her started. I'm pretty exited to get back to the forum! Thanks guys
Flatpat
Warda, TX
Patrick
12v Cummins
Glad you're okay. Those heavy trucks don't like being on their roofs.
Milblazer
Colorado
MilBlazer
That dodge doesn't look too repairable. I'm guessing its totaled or close to? If the drive train is still good I say go for it. It's good that everyone is unhurt.
Stewzer55
Ohio
Stew
R30
Wrecked Dodges make good donors to Square body Chevies.
You can get started with taking your engine and trans out of the CC before having to spend a dime, the biggest things you're going to have to worry about is the mounts for the Cummins, and then adapting the T-case and driveshafts.
If I were you, I'd keep the CC 2wd since its much easier to put a Cummins in the 2wd frame and convert the tailshaft to 2wd and fix the 5th gear nut and the KDP in the engine
fowjacob
Lubbock,TX
c3500
383 Stroker
I already have the motor and trans out of the chevy. Ive seen where they take the chevy isolator out and put a 1st gen mount where the isolator used to be. Anyone done this? I really want a 4x4 and the chevy has a ton of sentimental value. I dont know if its going to be worth adapting all the dodge 4x4 stuff or selling it and finding a chevy D60. But then i would need a new TC?
Also: kdp has already been fixed
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
I have , it's a pretty easy swap ! If you need any info I've done this swap 3 times now
