Cummins Coversion wiring/computer questions
td87
CT
Trevor
V20
I'm installing a 94 12v with a dodge auto, into my 85/87 1 ton. I was wondering if anyone knows what I should do about the computer and wiring. There appears to be alot more spaghetti in this dodge engine compartment than I was expecting. Any feedback would be appreciated, thanks
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
What computer, should be able to just tuck the wires and run basic ignition wiring.
Rollin_Thunder
Oklahoma City, OK
Robert
K30 SRW
12 valves aren't run on computers, everything is mechanical. If you had a 24 valve then you would have a problem.
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
No computer ! One wire to starter , battery ground , engine hot from the Chevys coil pack to the cummins injection pump , (pink) , engine ground. , hot battery to starter. .... Done
td87
CT
Trevor
V20
Does anyone know about wiring for the dodge auto trans?
lowcharacter
Riverside, CA
Jonathan
C30
12v Cummins
I'm currently installing a 47re trans in my project. I have compiled pin outs and pic diagrams and what I've done so far. Was waiting till I got it running to make sure I had everything right, but I can give you what I know so far
columnshift
Minnesota
Mark
1500 heavy half (retired)
You might find it easier to look for a 47RH transmission instead - the strength should be identical, just 100% hydraulic so no wires to mess with. Thats what i'd considered doing for a potential cummins swap before deciding i'd rather go nv4500 manual.
Alternately there's that megasquirt system for DIY fuel injection, they have a sister project of sorts (whose name I forget) meant for controlling electronic transmissions and such... there may even be a crude way to control it just with switches at the start - a guy on youtube used a 4L80E with no computer or controller, just manually hooked 3 switches to the servo controls (2 switches for binary control of the 4 forward gears, 1 for converter lockup I believe). The early electronic transmissions were pretty simple.
sallyjeank10
