crew cab carpet?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i bought a carpet set from stockinteriors.com for my crew cab.
it has weird humps where the rear seat belt would mount almost like its supose to cover te seat belt retractor thing but it is way wrong. they have sent a replacement and it the exact same. i am going to send it back and buy from some place else.
has anyone bought crew cab carpet and how good does it fit and where did you get it from.
I need to buy carpet for mine too. Can you get a pic of what you're dealing with? Is it 2-piece carpet, or all one piece?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
it is a two peice set front and rear
i have no hump like that on my floor
That's odd ain't it.
Looks like the carpet in general is a little lumpy and bumpy.
Guardian
Jeff
c 10
I bought mine from LMC and it fit great. I did buy the crew cab carpet but my truck isn't a crew cab; I used the extra carpet to cover the back of the cab since I have buckect seats in it.
That's a good idea! Did you put it on the back of the cab with spray adhesive then?
Guardian
Jeff
c 10
Yes. I did a scuff sanding and adhesive but I used a trim place from the back of the headliner to secure the end near the back glass.
3pairs12
Dale
I like that. I have a bench but pulled that cardboard shelf behind it out and was trying to figure out what to do.
fowjacob
Lubbock,TX
c3500
383 Stroker
Mine came like that to. after you start cutting the carpet to fit it will fit there. they sent you extra carpet on purpose and it just bubbles up there for some reason
ill show you a pic of mine when i get home
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i had the mass backing on it so it would not streatch out
where did you buy yours
and you said the hump was the same?
fowjacob
Lubbock,TX
c3500
383 Stroker
I bought my at stockinteriors, I didn't have the mass backing, but that shouldn't matter. It shouldn't stretch out. When you start cutting it to fit you have to cut some of that hump and after you cut it it fit rights in
That's about where that hump is in the carpet by the rear seat belt. sorry for the ****** pic but after you start cutting it should lay right in
K5Chris
