Correcting my speedo.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
Hey gent need help, i need to change my speedo gear but everything i find on line (summit) looks diff than wat i got. :help:
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
That little gizmo on the left side of the first pic is used to recalibrate the speedo. around here i can go the the truck parts stores (peterbuilt) and ect and get one made. you first need to know the ratio you need. so remove the gizmo and screw your speedo cable in without the gizmo find a gps and compair your speedo says to the gps at 60 Mph and give then the numbers at the shop and they should be able to hook you up.
Kapdin
North Dakota
Lance
huh.... sounds ez enough.. now to find a store that can. U say a truck dealer?
elstm3
montana
lynn
V30 crew cab dually
yea a semi truck dealer, or store that sells parts and accessories for them.
Kapdin
North Dakota
Lance
Well once again minot fails me and not a single shop will make one or knows wat im talking about. I spent 2 hrs calling around and asking and the most i got was a place on line called speedometer world that will make one when i call with my specs...... But actualy i just took that adapter off and ran it and its actualy pretty close as comparied to other cars i didnt have my gps today.
87Chevy520AZ
