Cluster repinned, no charge
Partsman
Buhl, Idaho
Mark
v20
5.7l 350 cid
I repinned the cluster on my 1987 chevy v20 Scottsdale and now the alternator doesn't kick on. Do I need to put a dummy light in line with the brown wire coming from the alternator?
Partsman
Buhl, Idaho
Mark
v20
5.7l 350 cid
Ok, I spiced a 194 bulb and socket between the two brown wires. The bulb lights up when I start the truck, but doesn't go out and I'm not getting more than 12v out of the alternator
Partsman
Buhl, Idaho
Mark
v20
5.7l 350 cid
I know that one side goes to the alternator and the other side goes to the heater fuse. Which is not blown.
nvrenuf
Mobile, Al.
This is the diagram I used when i rewired my ‘91, I also used this AC Delco plug.
The bulb (resistor) is always on while it’s running.
Partsman
Buhl, Idaho
Mark
v20
5.7l 350 cid
My 87 still has the 2 wire plug and I'm getting power back to the brown wire at the alternator
nvrenuf
Mobile, Al.
I had to rewire mine almost from scratch using that diagram, mine charges around 14v now. Aside from lighting, I don't really have any of the original engine or dash harness left though so it was easier than tying it into the real harness.
Partsman
Buhl, Idaho
Mark
v20
5.7l 350 cid
I repinned the dash
after changing from idiot lights to gauges
Dons79C10
