Cheap radio
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I have a radio in my attic that came out of an 84 gmc. Am/fm tape deck but I’m not sure the tape player is functional. I’ll see if I can dig it out of your interested.
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Got one radio on the way. I'll let you know if I need it.
Thanks.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got a GM AM/FM supposedly 78 Caprice. States on the top, stamped into the steel cover "DO NOT OPERATE WITHOUT 8 to 10 OHM SPEAKERS" Also GM part # 16001650. So if you are looking for speakers you better be sure to get what matches your unit.
I pulled my original gm stereo and replaced it with a JVC tape deck unit in my 75 c20 in 1987. I never bothered to look at it to see what it called for. Every system I ever put in my vehicles since then have all been 4 ohm speakers. But if Idaho read that on the unit then I would check to make sure you don't mess up the unit.
Now I've always installed aftermarket systems in a ton of vehicles. So I can't speak on old OEM stereos. I don' know when they went to 4 ohm speakers but I'm 99% sure they are 4 ohm systems now. So like Idaho stated better check just to make sure. I'd hate to tell you to use 4 ohm speakers and have it fry your radio.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Every time this thread title pops up this pops in to my mind:
scwaters
Chester Springs, PA
Sunny
K10 Shortbed 4x4
Add me to the list of people looking for an OEM radio fr 76 K10
73c20jim
Sierra Vista, AZ
What is MINIMUM gauge wire to run to speakers???
crpntr78
Missouri
I'm guessing a 16 gauge but I ran 14 gauge on mine.
crpntr78
Missouri
Speaker pictures. 2 are from the front facing and 2 are from overhead.
dvdswan
Port Orchard, WA
Dave
I keep my eye out for those when I'm at the j/y, still no luck finding them.
MikeB
For a stock radio with 8-10 ohm speakers, even 20 gauge will work fine for short cable runs. I'd be concerned about 4 ohm speakers on a stock radio that was designed for 8-10 ohms. It would be at lest twice the current draw on the amplifier section, which could potentially cause a failure.
It's more money, but there are amplifiers available that take the speaker outputs from a stock radio and convert to amplified 4 ohm outputs. Also, if the radio is mono, not stereo, you can connect two 4 ohm speakers in series.
RobertSC69
