Cab rebuild
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If it was me I would het the 84 cab if it is good and cut the things off to fix your cab or do a cab swap
80 is old round eye style but with rectangle I believe and 84 is true square but sectioning would work but not for the faint at heart. Did it on an S10 and lots of measuring and pre cut bracing
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
http://www.jegs.com/i/Auto-Metal-Direct/106/425-4073/10002/-1
those are the outermost cab supports that the body mount sits under and the bolt goes up into this support. I'm not sure if you need the long one from front to rear or not.
If you order over a hundred dollars worth jegs ships it free and no oversized part charge on the cab pieces. jegs will ship to home for freight or summit they charge around $100 for truck freight, doors, hoods, bed sides, outer fenders ship truck freight, sometimes an outer fender won't go freight, and alot of the times now an inner fender doesn't.
http://www.jegs.com/i/Auto-Metal-Direct/106/405-4073-R/10002/-1
those pans are meant to drop in from the top and cover th emost area the others are replacments, they do not go up or out as far.
http://www.jegs.com/i/Auto-Metal-Direct/106/406-4073-L/10002/-1
those have your inner rocer on them, the outermost edge of the floor and such, depending on how bad the rust is in the lower lip of where the weatherstrip sits, how far back it goes this maybe the one you need.
http://www.jegs.com/i/Auto-Metal-Direct/106/440-4073-L/10002/-1
that one is basically the same piece but shorter, not as far back or forward.
http://www.jegs.com/i/Auto-Metal-Direct/106/450-4073-R/10002/-1
replacement style rocker, extends up the front pilar and up the rear.
http://www.jegs.com/i/Auto-Metal-Direct/106/402-4073-R/10002/-1
this is the area next to your foot, most of the time it's rotted, didn't see any inside pics but still here it is.
http://www.jegs.com/i/Auto-Metal-Direct/106/480-4073-2L/10002/-1
outer cab corner replacment type they do have some taller or wider depends on how bad yours ends up being
http://www.jegs.com/i/Key-Parts/576/0850-217L/10002/-1
these are the inner cab corners when you rip off the outer you'll most likely find this has rust as well.
that is a good video on replacing all that stuff alot of parts check them out
keep in mind as others told me keep the cab on the frame or make a jig to keep it as it is before tear down and rewelding in new pieces. Also if you buy bigger patches then you need you can always cut them down and use only what you need.
You're awesome! Thanks for the hard work!! We found a cab rust free for 450 delivered to the house. but id still like to restore the cab though.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
What year cab?
1973c10
Don
Another cab is the way to go
then when you get time you can rebuild the old one
Iowan
Iowa
Calvin
K1500
350 crate
79 cab I believe. I'm trying to get it, just need to raise some funds.
CSFJ
Sell a kidney, blood, whatever.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sell someone else’s it’s easier on your body......:evillol:
Doylestown ohio
K10 Silverado
I live n Ohio and found a stamping plant that makes lots of replacement parts. I use them because the steel they use is American and the same gauge . The name is tabco
CSFJ
Lol, yeah if I had any feelings to hurt, I still wouldn't be offended. :laughing1::laughing1:
joshuars
