Buying parkinglamps, need info
87ChevyR10
Kansas
NA
NA
NA
Greetings,
Bought an 87 R10 and it doesn't have the parkinglamp assy's behind the grill. I found a kit on LMC; however, there is no mention mounting hardware. What hardware will I need to mount the assy's? Also, how do I remove the grill to get to the mounting location?
Thanks!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I'm not sure on the mounting assemblies, but I can take a look at the 87' grill I have hanging in my shed and get back to you on that.
Removing the grill is pretty simple. You need to remove the headlight shrouds on each side (4 Torx screws, I think they are T15s). There should 5 or so 9/32 bolts on top of the core support, 1 on each side of the grille on the bottom near the headlights, and 1 bolt in the middle bottom that you have to access from underneath.
KAR1130
