Build thread 5.3 W/6L80e in a 1986
Houston Ben
Houston
Ben
Hey all,
It is starting!! I have a guy putting the engine in with Dirty Dingo mounts, then I will transport back to my house for the rest. I will be sending my harness off to 150tunes.com for re-work and have a local buy tune when all is in.
Question: For people who have done this with the 6L80e, how did you hook up the shift link????????
I know $h!t about this so be kind!!
Stand by for loads of questions!!
Ben
:popcorn:
Looking forward to this :popcorn: Are you doing any kind of refresh on the internals of that motor?
Houston Ben
Houston
Ben
Na, keeping it stock except for a tune. I would have liked to but the boss (wife) is already cursing me for this so I can't let it get too out of hand!! The engine only has 38,000 mi on it.
Yeah, I wasn't talking about getting crazy. I was just talking about freshening it up with new parts to ensure (hopefully) no issues. Did you hear it run prior to pulling it out? How did you confirm the 38k miles on the motor?
Houston Ben
Houston
Ben
I dind't hear it run (4 hour drive one way) but did confirm the vin with pictures on the dash of the vehicle with the power on that showed 38,***. Donor was a 2011 sivlerado with back end damage, the front end was fine.
83swb
CT
Hunter
83'
350/th350
Looking forward to some more info on the build :happy107:
Houston Ben
Houston
Ben
Good news... ShiftWorks says their KK02 will work for the shift link and only $45!
Houston Ben
Houston
Ben
I will have the truck back Wednesday with the trans and engine in and will post pics then. I will be sending the harness in either tomorrow or Wednesday for re-work and no I have to get some O2 sensors because the yard didn't send them so there's another $60-80!!
Houston Ben
Houston
Ben
The 6L80 is a little taller than the TH350 (at least stands taller in the same place) so I had to cut the center of the crossmember down an inch. Hopefully it will install good after this. There was clearance but didn't want to take the chance of it rattling the floor of the cab.
I will get it tomorrow and see how it looks!
Houston Ben
Houston
Ben
Well, here it is installed. I know, a little dirty but I will clean it up a bit.
Lookin good :waytogo:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Looks good! Make sure since you dropped the Trans. down a bit, that your driveline angles are still good when you get it all back together.
She looks good in there!!! That thing is going to roar! :D
