BU switch wiring
Sethisaac
Missouri
Seth
I bought an 82 k10 that has a lot of modifications. They engine swapped it from a diesel to a small block and moved the gear selector from the Column to the floor. I’m in the process of installing a painless wire harness and I can’t figure out where to hook up the BU switch wires since it is no longer on the column.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
All of the B&M Shifters I ever used had these micro switchess installed. P/N #80629
Sethisaac
Missouri
Seth
Which connection is the input and which is output.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I haven't had one of these shifters in 10 years, so I don't recall. Here a link to the back side of the switch. I read the instructions for a Star Shifter and it doesn't specify. The switch is open until the curved tab is depressed.
C20NamedWaylon109
