Rusty Nail
- Jan 29, 2015
- the other side of the internet
- Rusty
- C20
- 350sbc
You're a good sport Old Boy! Have a seat.
You will be interested in removal wiper cowl. This may prove tricky and you might nerds a proper tool. I'm afraid it's removal will/may be necessary to complete the repair with the best success.
Here we teeter on the A/C system beginnings as the vacuum door underneath the cowl controls the "vent" and "max AC" functions, allowing or denying fresh air or modernly called "re circulate" recirc function. Outside fresh or inside cabin, conditionrd air.
Probably have to take the cowl off to play with the vacuum pod and lines which control the operation from behind the AC controller.
This involves removing the wiper arms and is likely the most strenuous area of the rebuild.
Lucky for you the vacuum hoses have color coded track lines on them. Orange to orange, green to green, etc. It's easy.
Theres red and yellow...and you get it.
To ensure proper HEAT function, the door underneath the wiper cowl must be closed when the controller is slid to the hot side WHICH, in kind, operates the BLEND door, that your P.O. (previous owner) has forced to cool with that @Rusty Nail because when you remove the pin from the TEMP door, it stays half open - as you have witnessed.
Three doors I think is right.
They obviously were trying tobeliminate the residual heat from the cab but were doing it wrong. Instead of stopping water flow to the heater core, they went Neanderthal on your heater box and now you must repair it to re-establish that lost value to your truck's worth.
Gettin on winter and heater/defroster is priority. You can remove the homemade block off and see what's in there. Clean it real good so it won't blow stink later.
I have to do work. Hold on ill be back.
The #10s in the pic are little foamy gasket type deals that you have to buy - or make?
