Brake Pedal switch bracket
Tja1161
Southern California
Tom
GMC JIMMY K5, 1985 K2500
Hello,
I am converting a Hydroboost system to a Vac Booster. I have already picked up a automatic brake pedal which has a slightly smaller pin and position. What I need to find is the part in the picture for a 73-87 Power brake vehicle.
Vehicle is 1983 Jimmy. Originally a 6.2 but converted to gas. Thanks
Tja1161
Southern California
Tom
Also it might be helpful for others converting to see the difference in hydroboost pedal and power brake pedal
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Why wouldn't you keep the hydroboost? They give a lot more braking assist.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Tja1161
Southern California
Tom
I have had both and I don't want to use on this vehicle. I lost a hydraulic line one time and had no brakes and a big mess.
Again, I am just asking if someone would know where I can buy the part. I don't want to debate why or why not because it is a matter of opinion.
Thanks for your help.
ajd89
Central Michigan
andrew
I can look I might have one sitting in the shed
Edit: Found 2 is the one in your pic from the hydroboost? These have the hole in different spot. You didnt say in your other pic which pedal was what.
Tja1161
Southern California
Tom
Yes, the one in picture is from Hydroboost. I will post more pictures shortly
Tja1161
Southern California
Tom
Here are the pedals side by side. The Power Vac pedal on left and Hydroboost on right
You can see the Power Vac pedal hole is higher up in this below picture
Let me know how much you want for that . If you want send me a PM
Thanks a bunch
jcuriel512
